FPGA Intellectual Property
6670 Discussions
Control Ethernet external mcu instead of nios
hi! everybody
because System design requirements,I want to Control Ethernet external mcu instead of niosII. I glanced at the datasheet,the ehernet IP interface is comminucate to niosII with avalon bus。
if i only minic the avalon bus timing to use MCU control ethernet instead of nios。
i have not use Ethernet and niosII before,some body who can give me some
detailed sugestion!
thankyou!
What is the reason not to use Nios? Nios II/e is really small cpu.
If You want to control the PHY using external CPU, then connect PHY MDIO to that CPU.
