FPGA Intellectual Property
6673 Discussions
Critical Warning: PLL clock
nome
Hello
We are porting  Arria ii gx Nios processor in ddr2 IP and ddr2 clock feed from PLL C0 and PLL IP directly connected  from FPGA clock I am facing some below critical warnings
I google this kind of warnings  I found this is PLL  IP main In clock issue maybe we have to make or add something  in SDC file
please help us how to add clock arrangement in SDC file
Critical Warning: PLL clock inst0_nios_cpu|lms_ctr_inst0|ddr2_1|lms_ctr_ddr2_1_controller_phy_inst|lms_ctr_ddr2_1_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy_inst|clk|full_rate.pll|altpll_component|auto_generated|pll1|clk[4] not driven by a dedicated clock pin or neighboring PLL source. To ensure minimum jitter on memory interface clock outputs, the PLL clock source should be a dedicated PLL input clock pin or an output of the neighboring PLL.
Nome
sstrell
The warning is pretty self explanatory.  It's not an SDC issue.  As the message says, you're not driving the PLL from a dedicated clock input pin or from another PLL.
nome
Hello
Thanks for your Reply
 In Nios processor  ALTPLL intel FPGA IP clock in I have connected with main FPGA CLK50
All Critical Warning I post below
Critical Warning: PLL clock inst0_nios_cpu|lms_ctr_inst0|ddr2_1|lms_ctr_ddr2_1_controller_phy_inst|lms_ctr_ddr2_1_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy_inst|clk|full_rate.pll|altpll_component|auto_generated|pll1|clk[1] driven through clock routing. To ensure minimum jitter on memory interface clock outputs, the PLL clock source should be a dedicated clock pin on the same side.
Critical Warning: PLL clock inst0_nios_cpu|lms_ctr_inst0|ddr2_1|lms_ctr_ddr2_1_controller_phy_inst|lms_ctr_ddr2_1_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy_inst|clk|full_rate.pll|altpll_component|auto_generated|pll1|clk[4] driven through clock routing. To ensure minimum jitter on memory interface clock outputs, the PLL clock source should be a dedicated clock pin on the same side.
Critical Warning: PLL clock inst0_nios_cpu|lms_ctr_inst0|ddr2_1|lms_ctr_ddr2_1_controller_phy_inst|lms_ctr_ddr2_1_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy_inst|clk|full_rate.pll|altpll_component|auto_generated|pll1|clk[1] not driven by a dedicated clock pin or neighboring PLL source. To ensure minimum jitter on memory interface clock outputs, the PLL clock source should be a dedicated PLL input clock pin or an output of the neighboring PLL.
Critical Warning: Warning (307070): Input clock of the PLL nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_PLL_0:pll_0|lms_ctr_PLL_0_altpll_hcc2:sd1|pll7 must be fed by a dedicated input pin.
Critical Warning: Warning (307072): Input clock to the ALTMEMPHY PLL, nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_ddr2_1:ddr2_1|lms_ctr_ddr2_1_controller_phy:lms_ctr_ddr2_1_controller_phy_inst|lms_ctr_ddr2_1_phy:lms_ctr_ddr2_1_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy:lms_ctr_ddr2_1_phy_alt_mem_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy_clk_reset:clk|lms_ctr_ddr2_1_phy_alt_mem_phy_pll:full_rate.pll|altpll:altpll_component|altpll_r0p3:auto_generated|clk[1], when fed by another PLL, must come from the dedicated PLL to the PLL cascade path.
Critical Warning: Warning (307074): Source PLL, nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_PLL_0:pll_0|lms_ctr_PLL_0_altpll_hcc2:sd1|pll7, which is feeding the PLL, nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_ddr2_1:ddr2_1|lms_ctr_ddr2_1_controller_phy:lms_ctr_ddr2_1_controller_phy_inst|lms_ctr_ddr2_1_phy:lms_ctr_ddr2_1_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy:lms_ctr_ddr2_1_phy_alt_mem_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy_clk_reset:clk|lms_ctr_ddr2_1_phy_alt_mem_phy_pll:full_rate.pll|altpll:altpll_component|altpll_r0p3:auto_generated|clk[1], must have the compensation mode set to No Compensation instead of Normal
Critical Warning: Warning (307072): Input clock to the ALTMEMPHY PLL, nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_ddr2_1:ddr2_1|lms_ctr_ddr2_1_controller_phy:lms_ctr_ddr2_1_controller_phy_inst|lms_ctr_ddr2_1_phy:lms_ctr_ddr2_1_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy:lms_ctr_ddr2_1_phy_alt_mem_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy_clk_reset:clk|lms_ctr_ddr2_1_phy_alt_mem_phy_pll:full_rate.pll|altpll:altpll_component|altpll_r0p3:auto_generated|clk[3], when fed by another PLL, must come from the dedicated PLL to the PLL cascade path.
Critical Warning: Warning (307074): Source PLL, nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_PLL_0:pll_0|lms_ctr_PLL_0_altpll_hcc2:sd1|pll7, which is feeding the PLL, nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_ddr2_1:ddr2_1|lms_ctr_ddr2_1_controller_phy:lms_ctr_ddr2_1_controller_phy_inst|lms_ctr_ddr2_1_phy:lms_ctr_ddr2_1_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy:lms_ctr_ddr2_1_phy_alt_mem_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy_clk_reset:clk|lms_ctr_ddr2_1_phy_alt_mem_phy_pll:full_rate.pll|altpll:altpll_component|altpll_r0p3:auto_generated|clk[3], must have the compensation mode set to No Compensation instead of Normal
Critical Warning: Read Capture and Write timing analyses may not be valid due to violated timing model assumptions
Critical Warning: See violated timing model assumptions in previous timing analysis above
Nome
nome
Hello
In QSYS  Nios processor ALTPLL IP clock input already connected with main FPGA 50mhz clk50
I follow up this below discussion link  but couldn't get remove these warnings
https://community.intel.com/t5/Intel-Quartus-Prime-Software/PLL-is-not-fully-compensated/m-p/554220
Below I am posting all our  Critical  Warnings
Nome
sstrell
So again, the issue is the connection to the reference input to the PLL, also as discussed in the older thread you linked to.  How is the input connected?  It should be to a dedicated clock pin or from the output of another PLL.
nome
Hello
I am totally confuse about your question Sir  I connect  PLL clock with 50Mhz from FPGA main clock .
maybe I can't recognize your question  that's why  I am sharing my project Archive
please help me where I am wrong
Please find attachment
Nome
nome
Hello
Still waiting Reply from Intel Altera .
Best Regards
nome
I am trying to resolve critical warnings when using the DDR2 IP. I have noticed that the DDR2 Ref_clk is directly connected to the PLL_C0, which is set to output at 100MHz. I am unsure how to handle the Ref_clk if I export the ref_clk in platform designer,
as it results in an error.
Even when I export and use pll_c0 in the top level as connected ddr_clk
, I encounter an error during compilation.
I have come across the ALTCLKCTRL IP, but I am unsure how to implement it on top of my design.
My question is, how can I solve these problems in handling the ref_clk for the DDR2 IP?
