FPGA Intellectual Property
6670 Discussions
Custom IP Simulation in ModelSim
Hi all,
I have a Custom IP developed in VHDL and i am able to communicate with the NiosII Soft processor.But when i simulate the Nios II processor,the communication between the Nios II and the IP is not as expected.
If i watch the slave_write and chip_select ,then in between the consecutive slave_write pulses,there comes a slave_read pulse also.
How to avoid the slave_read pulses in between?
Usually, the slave write/read is controlled in the application code. You might want to check your code and see whether you have inserted the reads.
I have checked the application code .I am only allowing two writes from the code.No read operation i am doing in between.
But when i simulate in modelsim,it shows a read signal in between the two write operation.
Are you using the io.h to perform IOWR_32DIRECT? Is Nios the only master to your custom IP?
Is the write instruction writing a whole word, or only a partial word - ie is the processor reading the full word, modifying the data and then writing back the full word having left the top byte unchanged, or similar?
--- Quote Start ---
--- Quote End ---
Yes,I am using io.h to perform the write operation and Nios is the only master to the custom IP
--- Quote Start ---
--- Quote End ---
The write instruction is writing the whole word(32 bit data)
Did you trace back the read to Nios?
What happens if you remove the writes from your application?
What is your custom IP doing?
