Hi all,
has anyone implemented a FFT custom instruction for NIOS, in order to provide hardware acceleration? I don't want to use the C2H tool. I'd rather use the FFT megacore (possibly with Simulink and DSP Builder). I'm looking for a design example to help me getting started. It could be another similar core, such as a FIR or a simple multiply accumulate function. I already have a good experience with the FFT but I am new to NIOS. ThanksLink Copied
Hi
You can check the below link for DSP related Reference design and design examples 1) http://www.altera.com/products/ip/dsp/ipm-index.jsp 2) http://www.altera.com/support/examples/dsp-builder/exm-dsp-builder.html- Mark as New
Hi
Can you please tell where we can find the reference design in zip format, which we can download from altera website? I am not able to find it. ex. executable file gold_code_generator.zip- Mark as New
hi
You can download the gold code generator from the MATLAB site 1) http://www.mathworks.com/matlabcentral/fileexchange/17440-generation-of-gold-codes and if you want to download any Altera reference design then go to the altera web site and click on the reference design then you get all the reference design which altera have and then click on the selected reference design which you want to download and then log in. after that you are able to download the complete reference design in a zip format :) i think that much info is sufficient for you- Mark as New
--- Quote Start --- and if you want to download any Altera reference design then go to the altera web site and click on the reference design then you get all the reference design which altera have and then click on the selected reference design which you want to download and then log in. after that you are able to download the complete reference design in a zip format :) --- Quote End --- unfortunately this is not true in cases where the application note has been removed, as seems to be the case with AN295, the gold code generator.
Topic Options
