From my understand from the external memory handbook, looks like if I want to use Cyclone 5 ddr3, I can use either hard or soft memory controller? What is the difference between these 2 types of controller?
Hi Sir,
hard memory controller always give the better performance compare to soft memory controller. I will suggest you to use hard memory controller if you starting a new design. I believe the soft controller is maintain in Cyclone V device is because is for some user that upgrading their design from older device and do not want to make big changes to their existing working design.
ok thanks!
you are welcome
