Community
cancel
Showing results for
Search instead for
Did you mean:
OShal2
Cyclone IV EP4EC30 migration to Cyclone IV EP4EC40.
I am currently using the EP4EC30 FPGA in the BGA780 package.
I am think to upgrade in the future to the EP4EC40 version.
I checked and found out that those devices are pin compatible (BGA780 pins package).
Is there anything important to know / do before doing such a change?
Are those devices compatible (pin / code / anything else?).
ChiaLing_T_Intel
Hi Oshal2,
Thank you for contacting Intel Community. When the migration feature is enabled in your design, you should always follow the common pin placement as stated in the Quartus Prime software Pin Migration Window in the Pin Planner. During migration, these NC pins may be connected to power, ground, or a signal trace depending on the common pin migration assignment of the devices selected for migration.
Thank you
Chia Ling
