FPGA Intellectual Property
6669 Discussions
Cyclone V - LPDDR2 problems - Guaranteed read failure
Mikexx
This is an implementation on a bespoke board that compiles/synthesises but fails calibration as indicated by Signal Tap.
I have implemented the External Memory Interface Toolkit and really all that seems to tell me is the IP has failed immediately on
  1: Read Calibration - Guaranteed read failure
I have scoped most[1] of the signals between the FPGA and SDRAM and they all toggle during reset or a calibration. ([1] There are DQs that are non-trivial to get to.)
The board has had the memory changed and is not something I want to do again.  The pinouts have been checked and rechecked.
The memory I am using is an ISSI device which should be JEDEC compatible and I have checked has the same set of Mode Registers as a Micron device.
Apart from writing my own diagnostic module to check things like operation of mode register etc, I feel utterly stuck.
The IP has a minimum speed of 166MHz which is a shame as the memory can run down to 10MHz.
Can anyone enlighten me to anything I can do to understand the failure and move forward?
yoichiK_intel
Hi
I do not know if this helps ,but there is  Hardware Debugging Guidelines in the document if you need additional debugging items.
starting page 565
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/external-memory/emi_plan.pdf
