FPGA Intellectual Property
DDR-2 IP data error
Hi All,
We are working on DDR2-IP on two different Altera cyclone III EP3C120F780C7N development kit
1st-kit, called as A-kit
The DDR(Micron) part number: combination of 8LD42-D9GMG and 8FB41-D90PN
2nd-kit, called as B-kit
The DDR(Micron) part number: combination of 8YF12-D9JLR and 8EB41-D9DPN
The data write and read are working good with the A-kit where as there is data corruption on some addresses while working on B-kit. We used the signal tap to check DDR-2 protocol, the protocol seems to be non-violated.
Can anyone experienced the some similar problem, please do send the response on how we can handle this case.
Thanks and Regards,
Vijay K
Timings are ok? What's the max freq of each chip? What's the controller freq?
