FPGA Intellectual Property
6102 Discussions
DDR2 Ip Core 3.3 vs 7.2
is there a big deference between the 3.3 and the 7.2 version of the DDR2 ram ip core from altera?
i have a project with a 3.3 version in it an i would like to upgrade it to the 7.2 version.
any one done this? wat are the pitfals? and is the interface the same?
thx a lot.
The 3.3 is a standalone core while the 7.2 comes with the Quartus II. I believe some timing numbers and bug fixes are done in the 7.2 and also 7.2 might support more devices. The interface should be the same.
The 7.2 also comes with a high performance one which uses the Altmemphy. That is totally different than the 3.3 version.
