It doesn't look like the I/O standard is your issue. It looks like your pin location assignments are the problem.
Hi
Thanks, I Have resolved my clock signal issue.(it is related port direction in top file)
now I am getting error for dq signals.
I am using 7A bank for ddr3 io mapping
I have properly configured that. the following error is reporting for the design,
Looks like that pin cannot be used for DQ. Are you doing this in Pin Planner? Have you set the view for x8/x9 to highlight the pins supported for these functions?
Yes, I am doing it in pin planner only with the highlights of DQ pins. i have assigned in dq pins only. I am sharing pin details sheet with this. can you please help me to resolve this?
do we need to connect rzq signal to ground?
FPGA DEVICE: 5CGXFC5C6F27C7
To | Direction | Location | I/O Bank | VREF Group | Fitter Location | I/O Standard |
cas_n | Output | PIN_A9 | 7A | B7A_N0 | PIN_A9 | SSTL-15 Class I |
ck[1] | Output | PIN_H12 | 7A | B7A_N0 | PIN_H12 | Differential 1.5-V SSTL Class I |
ck[0] | Output | PIN_G15 | 7A | B7A_N0 | PIN_G15 | Differential 1.5-V SSTL Class I |
ck_n[1] | Output | PIN_G11 | 7A | B7A_N0 | PIN_G11 | Differential 1.5-V SSTL Class I |
ck_n[0] | Output | PIN_G14 | 7A | B7A_N0 | PIN_G14 | Differential 1.5-V SSTL Class I |
cke | Output | PIN_D21 | 7A | B7A_N0 | PIN_D21 | SSTL-15 Class I |
cs_n | Output | PIN_A16 | 7A | B7A_N0 | PIN_A16 | SSTL-15 Class I |
dm[3] | Output | PIN_B17 | 7A | B7A_N0 | PIN_B17 | SSTL-15 Class I |
dm[2] | Output | PIN_A18 | 7A | B7A_N0 | PIN_A18 | SSTL-15 Class I |
dm[1] | Output | PIN_C22 | 7A | B7A_N0 | PIN_C22 | SSTL-15 Class I |
dm[0] | Output | PIN_C12 | 7A | B7A_N0 | PIN_C12 | SSTL-15 Class I |
dq[31] | Bidir | PIN_D13 | 7A | B7A_N0 | PIN_D13 | SSTL-15 Class I |
dq[30] | Bidir | PIN_D15 | 7A | B7A_N0 | PIN_D15 | SSTL-15 Class I |
dq[29] | Bidir | PIN_A11 | 7A | B7A_N0 | PIN_A11 | SSTL-15 Class I |
dq[28] | Bidir | PIN_C14 | 7A | B7A_N0 | PIN_C14 | SSTL-15 Class I |
dq[27] | Bidir | PIN_D11 | 7A | B7A_N0 | PIN_D11 | SSTL-15 Class I |
dq[26] | Bidir | PIN_C19 | 7A | B7A_N0 | PIN_C19 | SSTL-15 Class I |
dq[25] | Bidir | PIN_C9 | 7A | B7A_N0 | PIN_C9 | SSTL-15 Class I |
dq[24] | Bidir | PIN_C18 | 7A | B7A_N0 | PIN_C18 | SSTL-15 Class I |
dq[23] | Bidir | PIN_C17 | 7A | B7A_N0 | PIN_C17 | SSTL-15 Class I |
dq[22] | Bidir | PIN_D16 | 7A | B7A_N0 | PIN_D16 | SSTL-15 Class I |
dq[21] | Bidir | PIN_E19 | 7A | B7A_N0 | PIN_E19 | SSTL-15 Class I |
dq[20] | Bidir | PIN_C10 | 7A | B7A_N0 | PIN_C10 | SSTL-15 Class I |
dq[19] | Bidir | PIN_M12 | 7A | B7A_N0 | PIN_M12 | SSTL-15 Class I |
dq[18] | Bidir | PIN_N12 | 7A | B7A_N0 | PIN_N12 | SSTL-15 Class I |
dq[17] | Bidir | PIN_C15 | 7A | B7A_N0 | PIN_C15 | SSTL-15 Class I |
dq[16] | Bidir | PIN_C20 | 7A | B7A_N0 | PIN_C20 | SSTL-15 Class I |
dq[15] | Bidir | PIN_B21 | 7A | B7A_N0 | PIN_B21 | SSTL-15 Class I |
dq[14] | Bidir | PIN_A24 | 7A | B7A_N0 | PIN_A24 | SSTL-15 Class I |
dq[13] | Bidir | PIN_B9 | 7A | B7A_N0 | PIN_B9 | SSTL-15 Class I |
dq[12] | Bidir | PIN_E10 | 7A | B7A_N0 | PIN_E10 | SSTL-15 Class I |
dq[11] | Bidir | PIN_B19 | 7A | B7A_N0 | PIN_B19 | SSTL-15 Class I |
dq[10] | Bidir | PIN_F16 | 7A | B7A_N0 | PIN_F16 | SSTL-15 Class I |
dq[9] | Bidir | PIN_E15 | 7A | B7A_N0 | PIN_E15 | SSTL-15 Class I |
dq[8] | Bidir | PIN_A13 | 7A | B7A_N0 | PIN_A13 | SSTL-15 Class I |
dq[7] | Bidir | PIN_A23 | 7A | B7A_N0 | PIN_A23 | SSTL-15 Class I |
dq[6] | Bidir | PIN_G12 | 7A | B7A_N0 | PIN_G12 | SSTL-15 Class I |
dq[5] | Bidir | PIN_B11 | 7A | B7A_N0 | PIN_B11 | SSTL-15 Class I |
dq[4] | Bidir | PIN_B10 | 7A | B7A_N0 | PIN_B10 | SSTL-15 Class I |
dq[3] | Bidir | PIN_A21 | 7A | B7A_N0 | PIN_A21 | SSTL-15 Class I |
dq[2] | Bidir | PIN_A17 | 7A | B7A_N0 | PIN_A17 | SSTL-15 Class I |
dq[1] | Bidir | PIN_A12 | 7A | B7A_N0 | PIN_A12 | SSTL-15 Class I |
dq[0] | Bidir | PIN_A8 | 7A | B7A_N0 | PIN_A8 | SSTL-15 Class I |
dqs[3] | Bidir | PIN_J12 | 7A | B7A_N0 | PIN_J12 | Differential 1.5-V SSTL Class I |
dqs[2] | Bidir | PIN_L12 | 7A | B7A_N0 | PIN_L12 | Differential 1.5-V SSTL Class I |
dqs[1] | Bidir | PIN_M11 | 7A | B7A_N0 | PIN_M11 | Differential 1.5-V SSTL Class I |
dqs[0] | Bidir | PIN_H18 | 7A | B7A_N0 | PIN_H18 | Differential 1.5-V SSTL Class I |
dqs_n[3] | Bidir | PIN_J11 | 7A | B7A_N0 | PIN_J11 | Differential 1.5-V SSTL Class I |
dqs_n[2] | Bidir | PIN_K11 | 7A | B7A_N0 | PIN_K11 | Differential 1.5-V SSTL Class I |
dqs_n[1] | Bidir | PIN_L11 | 7A | B7A_N0 | PIN_L11 | Differential 1.5-V SSTL Class I |
dqs_n[0] | Bidir | PIN_H17 | 7A | B7A_N0 | PIN_H17 | Differential 1.5-V SSTL Class I |
odt | Output | PIN_E11 | 7A | B7A_N0 | PIN_E11 | SSTL-15 Class I |
ras_n | Output | PIN_B20 | 7A | B7A_N0 | PIN_B20 | SSTL-15 Class I |
Have you check out the pin placement for DDR3 in Pin-Out file?
If not, you may download it in this page: https://www.intel.com/content/www/us/en/support/programmable/support-resources/devices/lit-dp.html#cyclone%C2%AEvdevices
For your selected device, the Pin-Out file should be 5CGXFC5.
Also can download with this link: https://cdrdv2.intel.com/v1/dl/getContent/657074
Adzim
As we do not receive any response from you on the previous reply that we have provided, I now transition this thread to community support. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
