FPGA Intellectual Property
6670 Discussions
DDR3 IP simulation error Error: (vsim-10000) Unresolved defparamreference to 'power_s
While simulatintg the DDR3 SDRAM Uniphy IP example desing I am getting below given Errors :-
Error: (vsim-10000) ./..//submodules/altera_mem_if_hard_memory_controller_top_cyclonev.sv(1621): Unresolved defparam reference to 'power_saving_exit_cycles' in hmc_inst.power_saving_exit_cycles.# Region: /ddr3_eg_example_sim/e0/if0/c0# ** Error: (vsim-10000) ./..//submodules/altera_mem_if_hard_memory_controller_top_cyclonev.sv(1622): Unresolved defparam reference to 'mem_clk_entry_cycles' in hmc_inst.mem_clk_entry_cycles.# Region: /ddr3_eg_example_sim/e0/if0/c0# ** Error: (vsim-10000) ./..//submodules/altera_mem_if_hard_memory_controller_top_cyclonev.sv(1623): Unresolved defparam reference to 'priority_remap' in hmc_inst.priority_remap.# Region: /ddr3_eg_example_sim/e0/if0/c0# ** Error: (vsim-10000) ./..//submodules/altera_mem_if_hard_memory_controller_top_cyclonev.sv(1624): Unresolved defparam reference to 'enable_burst_interrupt' in hmc_inst.enable_burst_interrupt.# Region: /ddr3_eg_example_sim/e0/if0/c0# ** Error: (vsim-10000) ./..//submodules/altera_mem_if_hard_memory_controller_top_cyclonev.sv(1625): Unresolved defparam reference to 'enable_burst_terminate' in hmc_inst.enable_burst_terminate.# Region: /ddr3_eg_example_sim/e0/if0/c0# ** Error: (vsim-10000) ./..//submodules/ddr3_eg_example_sim_e0_if0_p0_acv_hard_memphy.v(676): Unresolved defparam reference to 'm_hphy_ac_rom_init_file' in hphy_inst.m_hphy_ac_rom_init_file.# Region: /ddr3_eg_example_sim/e0/if0/p0/umemphy# ** Error: (vsim-10000) ./..//submodules/ddr3_eg_example_sim_e0_if0_p0_acv_hard_memphy.v(677): Unresolved defparam reference to 'm_hphy_inst_rom_init_file' in hphy_inst.m_hphy_inst_rom_init_file.# Region: /ddr3_eg_example_sim/e0/if0/p0/umemphy
The simulation is done as explained in the "emi.pdf" chapter 10 Simulating Memory IP
Software used for simulation is ModelSim ALTERA STARTER EDITION 10.0c.
So please let me know what could be the possible Fix to these Errors?
Hi kushal.....i am facing the same problem in ALtera Max 10...Did you find any solution of this problem? Appreciate your feedback.
