I have a "DDR3 SDRAM Controller with UniPHY Intel FPGA IP" instantiated on its own in a design with no other logic. When I compile the fitter is not able to place 8 pins. The error messages are in the image. The attached txt file has details.
When the fitter is at full liberty since I did not personally specify and pin location constrains, it is unable to fit all DDR3 pins into the banks 5 and 6. These are the only banks that can be used for DDR3 signals. Does this prove that DDR3 cannot be used with this device?
I am confused this DDR3 must be useable with the 10M16 range of MAX10 FPGAs but here the fitter fails.
The device used is the 10M16DAF256I6G.
What is the memory configuration/setup? The EMIF spec estimator for MAX 10 with DDR3 only indicates you can use only a single chip select, but you have CS1 in these errors. Fill in your info here to see:
Looks like the Pin assignments are incompatible for the following pins:
RAM_BA0
RAM_BA1
RAM_BA2
RAM_CAS
RAM_RAS
RAM_CS1
RAM_WE
RAM_ODT
These pins which need 1.5V are being assigned to Banks which are already configured for 1.2V . Check the pin assignments and change them to the proper Banks for 1.5V and compile. This should solve the issue.
