FPGA Intellectual Property
6673 Discussions
DDR3 memory controller Termination calibration error.
I am using DDR3 memory controller generated with UniPhy IP core, for Cyclone V device.
I have selected 'No sharing' mode for OCT sharing option. Also connected oct_rzqin port to the input pin.
But tool issues the following error when I run Analysis & Synthesis.
Error (15700): Termination calibration block atom "ddr3_mem_controller:DDR3_CONTROLLER_BOT|ddr3_mem_controller_0002:ddr3_mem_controller_inst|altera_mem_if_oct_cyclonev:oct0|sd1a_0" uses RZQIN port, which must be connected to a dedicated I/O atom with no other fanout
From the error message I undestood that oct_rzqin port should be connected to the dedicated I/O pin. But I have added pin lock constraint for these pin in my qsf file. I have no idea why still tool issues this error. Looking for the help from here. Thanks in advance.
I'm not sure what you mean by a "pin lock constraint" (a pin assignment in the Pin Planner?). In any case, if you make a pin assignment for the OCT, it must be to one of the dedicated RZQIN pins of your particular target device. Check your device's handbook to see which dedicated pins are available for this function or do a pin search in the Pin Planner.
Thanks sstrell.. I had assigned wrong pin to RZQIN port. It was solved when I assigned the dedicated pin.
I could solve the above error by assigning the dedicated pin for RZQIN port. But I am facing following errors during fitter.
Error (174052): I/O "io_bot_mem_dq[0]" has dynamic termination control connected, but does not use parallel termination
Error (174052): I/O "io_bot_mem_dq[15]" has dynamic termination control connected, but does not use parallel termination
Error (174052): I/O "io_bot_mem_dqs[0]" has dynamic termination control connected, but does not use parallel termination
Error (174052): I/O "io_bot_mem_dqs[1]" has dynamic termination control connected, but does not use parallel termination
Error (174052): I/O "io_bot_mem_dqs_n[0]" has dynamic termination control connected, but does not use parallel termination
Error (174052): I/O "io_bot_mem_dqs_n[1]" has dynamic termination control connected, but does not use parallel termination
It seems like fitter is giving this error for all the Inout ports of DDR3 memory interface. What does this error mean? What is causing this error to appear?
srinivasan
I am also getting the same error...can you please me how you rectify the error..
You need to add a parallel termination assignment on the I/O pins to work along with the OCT.
--- Quote Start ---
--- Quote End ---
How to add parallel termination assignment on I/O pins?
Pin Planner or Assignment Editor.
Perhaps you need to run the pin assignment ticker script.
go to tools, tcl_scripts... select <>_pin_assignments.tcl and click run.
(This message was posted on behalf of Intel Corporation)
