FPGA Intellectual Property
6669 Discussions
DSP Builder on Ubuntu Linux
Hi all,
I installed Matlab r2008a, it works fine.
I installed Quartus II 9.0, it works fine
I have had problems with DSP Builder.
The installation completed with no errors and in simulink are now present both "Altera DSP Builder Blockset" and "Altera DSP Builder Advanced Blockset".
When I open a new model and I drag any block in from Altera blockset (i.e. gain block) I get the following exception in the matlab command window:
Error in block : untitled/Gain
Java exception occurred:
java.lang.UnsatisfiedLinkError: com.altera.dspbuilder.simulation.Block.rename(Ljava/lang/String;)V
at com.altera.dspbuilder.simulation.Block.rename(Native Method)
at com.altera.dspbuilder.simulation.Block.setName(Unknown Source)
at com.altera.dspbuilder.simulation.Mask.init(Unknown Source)
this error issues for every operation I do.
I don't get how to I solve this issue, I checked the file permissions and environment variables.
Has anyone experience of DSP_builder on Ubuntu linux?
Thank you all in advance!
SOLVED
the environment variable QUARTUS_ROOTDIR, even if exported in the .bashrc file, is non set if the installation is executed by the command
$sudo ./install --setup_matlab
The variable is set if the superuser is invoked by the command "sudo -s" before.
In this way the installation command# ./install --setup_matlab
works properly.
