FPGA Intellectual Property
6670 Discussions
DVI input and DVI output
I have the problem that I am using Altera cyclone III EPC3C120 Development board.The design example requires an Bitec HSMC Quad Video input daughter card. But I don't have it.Instead I am planning to use the Bitec HSMC DVI input/output daughter card for input and output.
Can anyone help me with a sample design with DVI input and DVI output?
Sneha
I tried to run the code suggested by you but I am getting some errors.It is from the design example from http://www.bitec.ltd.uk/hsmc_dvi.html
DVI 1080P Loop-through CIV
This sof updates the EDID EEPROM on the HSMC DVI board to correctly report 1080P@60
They are
Error: Node instance "auto_inst" instantiates undefined entity "alt_vip_vfb_0_GN"
Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 802 warnings
Error: Peak virtual memory: 346 megabytes
Error: Processing ended: Mon Apr 04 11:12:36 2011
Error: Elapsed time: 00:00:18
Error: Total CPU time (on all processors): 00:00:22
Help please..
Rgds
Sneha
I also tried to run the design HSMC DVI 1080P SDRAM Loop-through Reference Design
But I am facing these errors:
Error: Node instance "auto_inst" instantiates undefined entity "my_alt_vip_vfb_top_GN"
Error: Node instance "auto_inst" instantiates undefined entity "my_alt_vip_vfb_bot_GN"
Can anyone explain what these errors mean?
