FPGA Intellectual Property
6665 Discussions
Dear Sir, I am using ALTLVDS_RX IP on a Cyclone V GX device, and noticing that for some reason the rx_locked pin of PLL is never being locked. Same problem noticed when PLL is set to shared between LVDS transmitter and receiver. DPA not active.
CSegu
I am using ALTLVDS_RX IP on a Cyclone V GX device, and noticing that for some reason the rx_locked pin of PLL is never being locked. Same problem noticed is PLL is set to shared between transmitter and receiver.
I am new to ALTLVDS_RX. Can you please provide me some guidelines on what might be the issue. I am using a deserializer of 8, one channel and data rate 400Mbps and clock frequency 50MHz.
Attached are the timing diagram showing that rx_locked not being asserted.
Rahul_S_Intel1
Hi, I am requesting to isolate the problem first, First make a simple LVDS Rx and requesting you to signal tap the signals. If still lock signal is not high, I am requesting to check the input to the clock ,is there any noise is been affected.
CSegu
Dear RSree, Now I am having rx_clock and tx_clock pins are locked high now. I went to check with oscilloscope for the LVDS transmitter output clock tx_outclock but this is not being generated. Why tx_outclock is not being generated? Regards, Clive
Rahul_S_Intel1
Hi, There could be multiple reasons for not generating the clock may be the input will not be proper. IP configuration will be proper or board level issues.
