when we loaded the precompiled sof file to the kit --- in nvide control panel its detecting the arria10gx card. but there is no display on source -4K TV.
we installed quartus prime 17.1 pro and the desing is
AN 776: Intel® Arria® 10 UHD Video Reference Design.
2. we have to use HDMI RX AND TX IP CODE DDR4 MEMORY WITH SOME LOGIC TO BE IMPLEMENTED IN THE CODE . I know vhdl language. not familiar verilog.
also not familiar with NIOS2 . SO FOR IMPLEMENTATION OF OUR LOGIC
WHICH IP CORES I HAVE TO USE .
pls give us the solution .
Hi Do you have chance to observe the LED status and try to change the resolution by pressing the button PB0,1 and 2?
As explained in Table 2 and 3 of the AN. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an776.pdf
can you share a screenshot how it show permission denied and make failed condition arrived.
And also where its tell no signal on monitor.
hi, I don't see any attachment. Can you please attach again. Also, based on your current description, it seem like completely different with what you reporting in the beginning. Please confirm what is the actual issue that you are facing now.
Hi Sir,
See the instruction from this link for the IDE installation
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/why-does-the-nios--ii-not-installed-after-full-installation-of-t.html
Hi Sir,
What do you mean by red mark during compilation? is it compilation error?
I don't see any image attach here.
Dear Sir,
as per the links attached by u, I installed nios2 _eclipse and crated example design again .
1.eclipse-cpp-mars-2-win32-x86_64
2.quartus-19.1-0.02-linux.run
I am attaching the images again.
still the warnings came after example design creation. and other one is after compilation warning
Regarding using which IP cores, it is depend on your application needs. I can't tell you which IP that you need without knowing your needs.
By the way, quartus also support VHDL.
Are you posting this note in correct thread? Previously you did mentioned that the design is already work in 18.1. Then now you mentioned about 17.1. What is the problem that you facing in 17.0? I don't see you attach anything. Please note that you should stick on latest quartus version. Only latest 3 quartus version is officially supported.
