when we loaded the precompiled sof file to the kit --- in nvide control panel its detecting the arria10gx card. but there is no display on source -4K TV.
we installed quartus prime 17.1 pro and the desing is
AN 776: Intel® Arria® 10 UHD Video Reference Design.
2. we have to use HDMI RX AND TX IP CODE DDR4 MEMORY WITH SOME LOGIC TO BE IMPLEMENTED IN THE CODE . I know vhdl language. not familiar verilog.
also not familiar with NIOS2 . SO FOR IMPLEMENTATION OF OUR LOGIC
WHICH IP CORES I HAVE TO USE .
pls give us the solution .
- « Previous
- 1
- 2
- Next »
Hello, looks like you don't have permission to rd/wr to the target directory. Please check with your IT team on how to get the write access to the directory.
Probably you have to open the nios command shell as administrator.
See if the NIOS generating issue affected by this:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2019/why-does-hdmi-intel--fpga-ip-design-example-do-not-generate-prog.html
By the way, your previous message seem broken and hard to understand. I think the reason is the image is missing. Please re-construct your message again so that I can understand your problem clearer. Thanks
- « Previous
- 1
- 2
- Next »
