Simulate the Random Number Generator IP Core with ModelSim. The same testbench, when choosing different devices, the simulation results of rand_num_data are quite different.
(1) When stratix iv (EP4SGX230KF40I3) is selected, rand_num_data is not synchronized with inclk. And when the clock frequency is increased to 320MHz, rand_num_data will have an indeterminate state Z.
(2) When Arria 10 (10AX027H4F34I3SG) is selected, rand_num_data is synchronized with inclk. And when the clock frequency is increased to 320MHz, rand_num_data is still output normally. So I would like to ask, when using the Random Number Generator IP Core, what are the different considerations for different devices?
- « Previous
- 1
- 2
- Next »
Continuing the previous reply, I added a figure about the errors of tcl console.
Regarding your observation where when increasing the frequency of the clock for SIV rand generator IP simulation, the simulation seems to have issue. For your information, I am able to replicate similar observation when increasing the frequency from 100MHz to 200MHz. I believe this is due to limitation of the simulation model at high frequency. However, in actual hardware implementation, the core performance should be limited your timing closure. As a workaround, you can simulate the functionality at 100MHz and then implement the actual frequency in your design.
Please let me know if there is any concern. Thank you.
Chee Pin
I will implement in my actual hardware.
Thanks very much!
Regarding the test bench template writer, for your information, I do not have much insight into it. Generally I would code the test bench from scratch or use the example design generated by the IP. However, for the SIV rand IP, seems like there is no example design generation supported. Sorry for the inconvenience. As a workaround, I would like to recommend you to code your test bench in RTL.
Chee Pin
I will do as you recommended.
Thank you!
Thanks lot for your help and update.
I ran into a difficult problem. When using the 17.1 standard version to create a random number IP, an error will be reported, see the text and the attachments.
I am very anxious and look forward to your reply, thank you.
Error: rand_gen_0: IP geneneration failed at file discovery, please tell Altera
Error: couldn't open "C:/Users/ADMINI~1/AppData/Local/Temp/alt8408_4688452438430321239.dir/0002_rand_gen_0_gen//rand_gen.prj/components/altera_rand_gen/altera_rand_gen_internal_hw.tcl": no such file or directory
while executing
"discover_files $proxy_file_set $tmp_dir"
(procedure "generate_all" line 16)
invoked from within
"generate_all $output_name QUARTUS_SYNTH"
(procedure "generate_quartus_synth" line 2)
invoked from within
"generate_quartus_synth rand_num_gen_rand_gen_0"
Error: qsys-generate failed with exit code 1: 2 Errors, 0 Warnings
- « Previous
- 1
- 2
- Next »
