FPGA Intellectual Property
6670 Discussions
Digit Reverse Order issue for INTEL FFT IP core
User1582192733150209
Hello Sir/Madam,
I am simulating the intel FFT IP core, and seems the index of non-natural order FFT output  is not fully match the index digi reverse calculation.
Quartus prime pro 17.1
Modelsim-intel  starter 10.5c
Windows 10 pro
Arria10gx
What I have done
1, create a Quartus project and install a Intel FFT IP core
2, Choose to generate the testbench when setting up the FFT IP core
3,start modelsm and compile vendor/user library using automatic generated msim_setup.tcl
4,use matlab2019b to generate IEEE754 format  data source, 32bits single precision floating.
5,In testbench coding to load above data source into FFT input
6, simulation and observe FFT output
with above simulation flow ,I have done 2 simulation case, the difference is output order, one is natural order, another one is digit reverse. I will explain it one by one.
case 1
FFT configuration is as below
Length:256
Direction: forward
Data flow: variable streaming
Input order: Natural
Output order: Natural
Representation: single floating point
below is simulation , seems every signals are correct, and we can find 2 spike
at the output stream, one is at index 4, another one is at index 252.
because I use x = 10 * cos(2*pi*4*t) to generate data source in matlab2019b, so the above simulation result meet the my understanding, ie at 4hz(index 4) and symmetric location 252(index252) have 2 spike signals.
below is part of the m file used to generate signal source.
fs=256;N=256;
n=0:N-1;t=n/fs;
x = 10 * cos(2*pi*4*t);
y=fft(single(x),N);
mag=abs(y);
f=n*fs/N;
subplot(2,2,1),plot(x); %signal source
xlabel('time domain');
ylabel('Amptitude');title('Signal Source input N=256');grid on;
subplot(2,2,2),plot(f,mag);
xlabel('Frequency Domain/Hz');
ylabel('Amptitude');title('Direct FFT N=256');grid on;
realInput = real(x);
imagInput = imag(x);
realOutput = real(y);
imagOutput = imag(y);
realOutput_s =single(real(y));
imagOutput_s =single(imag(y));
for i = 1 : N
fprintf(f1,'%s\n',float2bin(single(realInput(i)))); % writing bin format sine_input_data_r.txt
fprintf(f1i,'%s\n',float2bin(single(imagInput(i)))); % writing bin format sine_input_data_i.txt
end
below is details about 2 location at index 4 and index 252
case 1 simulation meet my expectation.
case 2
the reason I test case 2 because when I was repeating input data source, need to keep a big IPG to avoid timing issue,you can check my SR https://community.intel.com/t5/FPGA-Intellectual-Property/Intel-FFT-IP-core-timing-issue/m-p/1190502#M21698 .
but that big IPG reduce the fft processing bandwidth, that is why I change to digit reverse to avoid timing issue, but seems I got another issue.
 case2 FFT configuration is as below
Length:256
Direction: forward
Output order: Digit reverse
based on the understanding for digit reverse option, the output index should be digit reverse for natural 8 bit index .
because these 2 case have same data source, so we can expect same result with different output order .
for example
the spike at index 4(00000100) in case 1,  in case 2  should be at index 32(00100000) , however I did find this spike ,but location is at 16(00010000) ,this is not match the address reverse calculation, this is my key question.
another spike at index 252(11111100) in case1,  in case 2   should be at index 63(00111111) ,I did find this spike in case and location is matched.no issue for this one.
let's check the simulation as below
I attached my 2 projects here for further analysis ,so you can duplicate my issue.
1,unzip my project,you can put it into the d:  , this is my original location
2,start modelsim
3, you might need edit the quartus path in msim_setup.tcl ,my quartus is located H:/intelfpga_pro/17.1/quartus/
4,goto D:\fftipsimulation\tfft\sim\mentor
source initial_setup.tcl
5,do run.do
6, if you need to control input data source only once
change multi_cycle=1'b0     in D:\fftipsimulation\tfft\sim\tfft_tb.v
7, you will see the issue I mentioned
thanks
Jim
Any update?
below is the MATLAB plot for FFT verification .
left top cornet one is for signal source
right  top cornet one is for direct FFT using matlab itself
with this we can expect 2 spike at index 4 and index 252.
the spike I mentioned is amplitude 1280.
thanks
Jim
CheePin_C_Intel
Hi Jim,
Thanks for your detailed elaboration of your issue observation. As I understand it, you have some inquiries related to the digit reverse of the FFT IP output. Please allow me some time to digest the information and to perform replication for further debugging. I will provide you an update on the progress by end of next week or as soon as there is any valid finding. Please ping me if you do not hear back from me. Thank you.
Hi CheePin,
Thanks for your time and effort.
Best regard
Jim
CheePin_C_Intel
For your information, as I tested running simple example design from Q17.0 std with bi-directional, length = 8 and fixed point, I can get the correct digit reverse order when comparing between the digit reverse and natural output test cases. Would you mind to try with dummy design + fixed point to see if can get the right index? To help us narrow down if this only occurs in floating point data format.
In the meantime, I will try to customize the example design to take in your data to see if can replicate any anomaly.
Thank you.
CheePin_C_Intel
Hi Jim,
For your information, I have found out why after digit reversal, your expected data is appearing at index 16 instead of 32. With your FFT configuration, the Radix-4 digit reversal is implied but not Radix-2. You can refer to System Messages at the bottom of your FFT configuration screenshot for the Radix-4 implied.
In your case, the spike is originally at index 4 (Radix-4 = 0010), after digit reversal, it become 0100 which is equivalent to digit-reversed index of 16 which tally with your simulation. As for the other spike at index 252, the digit-reversed index = 63 which tally with your simulation as well. Hope this explain.
Please let me know if there is any concern. Thank you.
Chee Pin
Hi Chee pin,
thanks for your effort.
I am not quite understand it.
Can you suggest how can I turn the digit reversed result back into natural order output using my 8 bits index? because I plan to turn result into natural order result in FPGA and forward it to next stream for further usage.
my current logic is
assign digi_reverse_index[fft_result_address_width-1:0] ={result_index[0], result_index[1], result_index[2], result_index[3],
result_index[4], result_index[5], result_index[6], result_index[7]};
integer i;
always @(posedge clk or negedge reset_n)
begin
if(!reset_n)
  begin
  for (i = 0; i < data_num-1; i = i + 1) begin
       fft_digireverse_result_r[i] <= 32'd0;
      fft_digireverse_result_i[i] <= 32'd0;
  end
end
else if(source_valid) begin
  fft_digireverse_result_r[digi_reverse_index] <=source_real ;
  fft_digireverse_result_i[digi_reverse_index] <=source_imag ;
end
end
thanks
Jim
I put form here to summary up, I am not sure with the same data source how can I use digit reverse output to figure out the target frequency .
CheePin_C_Intel
Sorry for the delay. Sorry as I am not very familiar with HDL design to implement the digit reverse. However, you can refer to the following mapping table for Radix-4 digit reverse for your 256 data to see if it is helpful.
 Original, Digitrev Radix-4
   0   0
   1   64
   2  128
   3  192
   4   16
   5   80
   6  144
   7  208
   8   32
   9   96
   10  160
   11  224
   12   48
   13  112
   14  176
   15  240
   16   4
   17   68
   18  132
   19  196
   20   20
   21   84
   22  148
   23  212
   24   36
   25  100
   26  164
   27  228
   28   52
   29  116
   30  180
   31  244
   32   8
   33   72
   34  136
   35  200
   36   24
   37   88
   38  152
   39  216
   40   40
   41  104
   42  168
   43  232
   44   56
   45  120
   46  184
   47  248
   48   12
   49   76
   50  140
   51  204
   52   28
   53   92
   54  156
   55  220
   56   44
   57  108
   58  172
   59  236
   60   60
   61  124
   62  188
   63  252
   64   1
   65   65
   66  129
   67  193
   68   17
   69   81
   70  145
   71  209
   72   33
   73   97
   74  161
   75  225
   76   49
   77  113
   78  177
   79  241
   80   5
   81   69
   82  133
   83  197
   84   21
   85   85
   86  149
   87  213
   88   37
   89  101
   90  165
   91  229
   92   53
   93  117
   94  181
   95  245
   96   9
   97   73
   98  137
   99  201
  100   25
  101   89
  102  153
  103  217
  104   41
  105  105
  106  169
  107  233
  108   57
  109  121
  110  185
  111  249
  112   13
  113   77
  114  141
  115  205
  116   29
  117   93
  118  157
  119  221
  120   45
  121  109
  122  173
  123  237
  124   61
  125  125
  126  189
  127  253
  128   2
  129   66
  130  130
  131  194
  132   18
  133   82
  134  146
  135  210
  136   34
  137   98
  138  162
  139  226
  140   50
  141  114
  142  178
  143  242
  144   6
  145   70
  146  134
  147  198
  148   22
  149   86
  150  150
  151  214
  152   38
  153  102
  154  166
  155  230
  156   54
  157  118
  158  182
  159  246
  160   10
  161   74
  162  138
  163  202
  164   26
  165   90
  166  154
  167  218
  168   42
  169  106
  170  170
  171  234
  172   58
  173  122
  174  186
  175  250
  176   14
  177   78
  178  142
  179  206
  180   30
  181   94
  182  158
  183  222
  184   46
  185  110
  186  174
  187  238
  188   62
  189  126
  190  190
  191  254
  192   3
  193   67
  194  131
  195  195
  196   19
  197   83
  198  147
  199  211
  200   35
  201   99
  202  163
  203  227
  204   51
  205  115
  206  179
  207  243
  208   7
  209   71
  210  135
  211  199
  212   23
  213   87
  214  151
  215  215
  216   39
  217  103
  218  167
  219  231
  220   55
  221  119
  222  183
  223  247
  224   11
  225   75
  226  139
  227  203
  228   27
  229   91
  230  155
  231  219
  232   43
  233  107
  234  171
  235  235
  236   59
  237  123
  238  187
  239  251
  240   15
  241   79
  242  143
  243  207
  244   31
  245   95
  246  159
  247  223
  248   47
  249  111
  250  175
  251  239
  252   63
  253  127
  254  191
  255  255
Hi CheePin,
Thanks for your explanation.
I think I got a bit understanding about digit reverse now .
for radix-4 ,floating representation data,below translation from digit reverse order to natural order index is verified for my case.
 Let's call the digit reversed index(non-natural order) as dr_index[7..0] 8 bits, then we call a natural order index na_index[7..0] ,below is my summary how to convert it
For my case, let verify it for the first spike at index 4
from above conversion ,index 4(8'b 00000100) will turn to index 16(8'b 00010000, ie index 4 turn to index 16 under digit reverse calculation,that matches the simulation result.
another spike, which presents at index 252(8'b 11111100) , should be at location index 63(8'b 00111111) under digit reverse order output.
that matches the simulation result too.
hope this summary can help more people to understand this index conversion.
In verilog ,can use below
assign na_index[7:0] ={dr_index[1], dr_index[0],
                                          dr_index[3], dr_index[2],
                                          dr_index[5], dr_index[4],
                                          dr_index[7], dr_index[6] };
thanks
Jim
CheePin_C_Intel
Hi Jim,
Thanks lot for your sharing.
I believe the initial inquiry has been addressed. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Hi CheePin,
yes ,please help to close this service request,  and my initial question has been addressed , thank you very much.
Jim
