FPGA Intellectual Property
6673 Discussions
Display Port Example Project
ANi
​The example project of display port is used. There is a bitec_clkrec  in it, which is an encryption module. Do you have any relevant documents to introduce the implementation of this module?
Deshi_Intel
HI,
Sorry, as this is proprietary encrypted IP from Bitec.
Hence, there is no doc to explain on the design implementation.
In general, we do expect user to use the Intel FPGA DisplayPort IP as complete solution instead of drilling into the IP sub block design implementation detail
Thanks for your understanding.
dlim
Deshi_Intel
HI,
I have not hear back from you for quite sometime.
Sorry Intel can't provide explanation on proprietary encrypted IP.
For now, I am setting this case to closure.
dlim
