FPGA Intellectual Property
DisplayPort
Hi all,
Normally the VESA mentions that the DP (with 4lines) is able to send 12-ppc YCbCr 4: 2: 2 (24 dpi) corresponding to 1920x1080p @ 120Hz
I would like to know what will be the DTM (Display Monitor Timing) appropriate for it and the format of the video interface DP_Source (TX_VID_V, TX_VID_H,TX_VID_DE).
The aim is to send a stream video from the Altera IP DisplayPort to the Altera IP HD-SDI.
Hayder
Afaik, SDI cannot do 120Hz. The Fastest format SDI is 3G-SDI (1080p @ 60Hz)
Hi Tricky,
I Have read the user guide of DP and the specification of VESA to be able to implement this IP in my own design. I was able to run the design simulation of altera with modelsim.
After that I created my owne design (DP-Sink plus thiers PHY and XCVR). The compilation passe without any error. But when I started the simulation of this design I have many error.
1- When I take a look into the DISPLAYPORT_02_run_msim_rtl_vhdl.do file I found that many file didn't compiled (exp: altera_dp_reconfig_ctrl.v)
2- The DP_SIM folder hadn't the entire file (altera_dp_reconfig_ctrl.v, altera_dp_reset_delay, altera_dp_status_sync).
I am wondring why the quartus messed to include this file in the simulation folder.
I suggest raising a support request for help with specific cores.
I am trying to implement a converter of an DisplayPort-RX to HDSDI-TX. In the simulation the design has a good functionning but during the synthetise (Place and route) I got an error that told me that the design had HSSI PMA conflicts (The CALCLK must be driven by the same source).
I am aware that the PHY-HDSDI and the PHY-DP have a different frequencies and I thought that the quartus will take this consideration to instantiate a different HSSI for each PHY. But when I got this error I am confiouse. and I thank one of the HSSI is used for RX Display and TX HDSDI and this way the conflit occurs.
Now I am wondring if existe any special contraints to resolve this confilt ?
thanks
ACont16
I am trying to implement a converter of an DisplayPort-RX to 3DSDI-TX. Can you say me which ip core can i use?
