FPGA Intellectual Property
6670 Discussions
Divider fail setup constraint
i can't meet constraints of a 64 bit divider,
i added 64 stages of latency inside divider.
How can i do?
use a slower clock?
i found the problem!!
if i disconnect the aclr, my divider setup slack increase noticeably!
i think if a reset is inferred, more logic is required so this slow down the divider.
if a reset isn't required, don't use it!!
i'm sorry i've not solved.
if i disconnect the aclr, the whole divider is kept in reset! so the timing are right but unuseful.
I tried to use a slower clock. I instantiated the PLL, the input of the PLL is Clock, the default signal.
I made 2 Outputs and i would use these in DSP Builder,
PLL_clk0 => 100MHz -- same frequency of Clock
PLL_clk1 => 50 MHz
am i right to run my design with the PLL_clk0 and the divider with the PLL_clk1 ?
