FPGA Intellectual Property
6118 Discussions
Dsp builder error in matlab R2014a
I try to add dsp standard block from simulink library broser to simulink model file and I have an error in matlab command window:
Problem occured with mask object. DSP Builder cannot find the Java classes it needs to work.
I can not save my simulink model file because i have an error.
And i have no error when i add an advanced dsp block to simulink model file. ))
What need to do to fix that?
--- Quote Start ---
You are in the wrong forum for this. Try: https://www.mathworks.com/matlabcentral/answers/index?s_tid=mlc_an_ask
--- Quote End ---
When installing DSP builder - https://alteraforum.com/forum/attachment.php?attachmentid=14803&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14803&stc=1 an error occured.
is it Matlab ?
