FPGA Intellectual Property
6670 Discussions
ERROR in generatoring Random Number Generator IP
Jessica
Quartus prime standard version 17.1 is used. The FPGA used is the Stratix IV family. When generating the random number generator IP core, the following error occurs.
Error: rand_gen_0: IP geneneration failed at file discovery, please tell Altera
Error: couldn't open "C:/Users/ADMINI~1/AppData/Local/Temp/alt8142_9067140267533821730.dir/0002_rand_gen_0_gen//rand_gen.prj/components/altera_rand_gen/altera_rand_gen_internal_hw.tcl": no such file or directory
  While executing
"discover_files $proxy_file_set $tmp_dir"
  (procedure "generate_all" line 16)
  Invoke from within
"generate_all $output_name SIM_VERILOG "
  (procedure "generate_sim_verilog" line 2)
  Invoke from within
"generate_sim_verilog random_normal_gen_rand_gen_0"
Error: qsys-generate failed with exit code 1: 2 Errors, 0 Warnings
Error: couldn't open "C:/Users/ADMINI~1/AppData/Local/Temp/alt8142_9067140267533821730.dir/0004_rand_gen_0_gen//rand_gen.prj/components/altera_rand_gen/altera_rand_gen_internal_hw.tcl": no such file or directory
  While executing
  Invoke from within
"generate_all $output_name QUARTUS_SYNTH"
  (procedure "generate_quartus_synth" line 2)
  Invoke from within
"generate_quartus_synth random_normal_gen_rand_gen_0"
MEIYAN_L_Intel
Can you try to update to Quartus Prime 18.1 which is latest version and provide support to Stratix IV family?
If the problem still persist, please tell me as well.
Jessica
Hi, The problem has been solved by changing the verision to Quartus Prime 17.0. Thanks!
