FPGA Intellectual Property
6670 Discussions
Embedded MATLAB code in DSP Builder
I need to use some MATLAB functions that I have in .m files in a DSP Builder project. In a first example I tried to use an Embedded MATLAB function block with a simple and inside, but I have this error when I try to analyze the model:
Matlab Error Error using ==> alt_dspbuilder_mdl2xml at 29 Error due to multiple causes. Error: Error during compilation: Error analyzing Model see log for details.
There is any way to integrate MATLAB code inside a DSP Builder project?
Thanks!
FYI, I found that the best (or the only) way to do that is translating de m function into VHDL via HDL Coder and then adding this HDL file with the HDL import block.
Maybe this was a silly question, but if someone needs an answer int he future that's the way I did it.
