Hi all, I am facing the following issue while compiling the design with parallel flash loader II IP.
Error (11176): C:\Users\murali.kumar\Desktop\OLD_SIM\learn\sim\pfl_design\db\ip\slde564a3bb\alt_sld_fab_wrapper_hw.tcl: There is an unnamed component definition in the file: C:/Users/murali.kumar/Desktop/OLD_SIM/learn/sim/pfl_design/db/ip/slde564a3bb/alt_sld_fab_wrapper_hw.tcl. Please see the command set_module_property NAME Error
(11176): No component alt_sld_fab in C:/Users/murali.kumar/Desktop/OLD_SIM/learn/sim/pfl_design/db/ip/slde564a3bb/alt_sld_fab_wrapper_hw.tcl Error
(12154): Can't elaborate inferred hierarchy "sld_hub:auto_hub"
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 3 errors, 1 warning
Error: Peak virtual memory: 4801 megabytes Error: Processing ended: Sat Sep 25 13:48:11 2021
Error: Elapsed time: 00:00:36
Error: Total CPU time (on all processors): 00:01:43
Error (293001): Quartus Prime Full Compilation was unsuccessful. 5 errors, 1 warning Kindly help me to solve the issue...
Thanks and Regards Murali_kumar
May i know what device you are using? What quartus version?
I have selected a MAX V device and working in quarts prime lite 20.01.1
Hi, i tried to compile the design with PFL II IP. No issue on my side. Do you instantiate the IP properly? Also, add the IP into the project directory properly?
Yes I have added the Ip files and instantiated properly. But still it was shown the same.
Can you try to create new design and put only the PFL II IP in it? Just want to isolate the root cause.
Yes,
I have tried only with this IP and still facing the same issue.
Is there any simple example design to compare with mine.
Murali
Murali
do you enable signal tap? Error (12154): Can't elaborate inferred hierarchy "sld_hub:auto_hub", sld_hub looks like signal tap related component. Can you try to create new project with only the IP instantiated? just want to isolate the issue.
