FPGA Intellectual Property
6568 Discussions
Error(12787): RX channel fmca_dp_m2c_p[0] and TX channel fmca_dp_c2m_p[0] are locked to the same dup
APPU_appu
Hi , @Intelfamily
Error(12787): RX channel fmca_dp_m2c_p[0] and TX channel fmca_dp_c2m_p[0] are locked to the same duplex channel. In order for both the RX and TX channel to use the same duplex channel, you must assign them to the same group so the Fitter merges them into a single Avalon Memory-Mapped interface. To assign both channels to a group, use the Transceiver Avalon Memory-Mapped Interface Group logic option.
This error i am facing while running fitter, i found this  "set_instance_assignment -name XCVR_RECONFIG_GROUP 1 -to fmca_dp_c2m_p[0] -entity top", if i use this cammond it will solve that error but even after using that one i am not able to solve that error can u please addres this issue
