FPGA Intellectual Property
6359 Discussions
Error: Can't place node "mem_addr[0]" -- illegal location assignment PIN_ N16
Hi everybody,
This error appears when I try to complie the example design generated by ALTMEMPHY IP, I don't understand what's the error meaning and why it appears,how can I handle with it?
Thank you for your advice~~~
Best regards
Angel
Posting the complete (expanded) error text would be necessary to understand the conflict nature, you should also tell the FPGA type. Problems of this kinds arise when not executing every step as suggested in the manual, e.g. not importing the tcl scripts with various assignments.
Hi, thank you for you advice, the problem has been soveled.
I placed the pin using the following way before:
assignment- import assignment- import the .avs document
Then I try to place the pin manually, the error disappeared.
Thank you all the same, I will give more error information next time~~~
Angel
please can you tell me what should I do when I have this kind of errrors:
Error (171016): Can't place node "mem_dq[0]" -- illegal location assignment 3
Thanks in advance;
