FPGA Intellectual Property
6673 Discussions
Error while generating DDR2 IP core for CycloneIV in Quartus13.1
Hi all,
Can anybody help me out to remove the following error I am getting while generating the core.
Error (332000): can't read "dqsclksource": no such variable
while executing
"create_generated_clock -multiply_by 1 -source $dqsclksource -master_clock $dqsclksource $dqspin -name $dqs_out_clockname -add"
(procedure "add_requirements_for_instance" line 263)
invoked from within
"add_requirements_for_instance $corename $inst t board ISI $DDR2_USB_phy_use_flexible_timing"
("foreach" body line 3)
invoked from within
"foreach inst $instance_list {
post_sdc_message info "Adding SDC requirements for $corename instance $inst"
add_requirements_for_instance $corename $..."
(file "DDR2_USB_phy_ddr_timing.sdc" line 635)
If I comment those lines in .sdc file, I am getting similar errors for other variables.
Thanks in advance.
