I am trying to test the functionality of FFT version 8.0. The device family that I am using is Cyclone II. Below is the parameter of the FFT: Transform Length: 64 points Data Precision: 8 bits Twiddle Precision: 8 bits I/O Data Flow: Streaming Structure: 4 Mults/2Adders Implement Multipliers in: DSP Blocks/Logic Cells Twiddle ROM Distribution 100% M4K As for the FFT input, I wrote a FSM code for it. My input looks fine, sink_sop, sink_eop and sink_valid are where it is suppose to be. However sink_ready was asserted at the beginning, one clock cycle before sink_valid and sink_sop were asserted. Then sink_ready was de-asserted half way before sink_eop (before 64 data ends). As a result, source_error shows “11”; meaning that EOP is asserted before 64 valid samples are accepted. Since I am using streaming architecture, I thought this architecture allows continuous processing of input data and outputs a continuous complex data stream. So that means the sink_ready was suppose to be asserted all the time isn’t it? Unlike in buffered burst and burst architecture, sink_ready signal will be de-asserted when FIFO is filled. So why for streaming architecture in my case, the sink_ready can be de-asserted causing it unable to accept data? Does anyone know this answer?Link Copied
- « Previous
- 1
- 2
- Next »
Hi thepancake, thanks for everything. I couldn't use Modelsim , cause the software is not included with the Quartus II Web Edition. But I will try to find other way to solve this. Hopefully...
there's a web edition of ModelSim too.
http://www.altera.com/products/software/quartus-ii/modelsim/qts-modelsim-index.html but in the second waveform i posted i just used the graphical testbench editor and Quartus simulator and got the correct results.- Mark as New
I got good news, for the problem (sink_valid goes low half way during input) the mistake was I did not turn on Global Clock Enable during code generation. The pin "clk_ena" needs to be there and set high for it to work properly, other wise there will be a warning like this: Can't find signal in vector source file for input pin "l fft_test1 l fftblock: inst l asj_fft_sglstream_fft_81 : asj_fft_sglstream_fft_81_inst l clk_ena"- Mark as New
Hi bellman,
would it be possible, that you upload your project-files? I am a bloody beginner and would like to see how you build up such a FFT. That would be great :) Regards, LarsD- Mark as New
hey bellman,
sorry i didn't get back to you, i've been swamped at work. glad you got it working and thanks for posting the solution.- Mark as New
Hi LarsD,
I could only post it to you few days later.. hope you could wait a little longer.. By the way, I had a little problem cause I am trying to compare my input (after goes through IFFT and FFT) and output to see if I could get back the original data. (I think it is called Unity Gain). Still trying to figure out, I think there is some operation such as scaling and 1/N multiplication involve. Get back to you soon.- Mark as New
Hi bellman,
I just get it ;) But thanks for your help!- Mark as New
hey bellman,
there is some Verilog in the Altera design example that should help you figure out the unity gain stuff. http://www.altera.com/support/examples/verilog/ver-cascaded-fft-ifft.html- Mark as New
i was able to modify the unity design example to work in Quartus 8.1 (i think the original design was 16-bit data/twiddle and streaming so that's what i used). the design example is basically taken from AN404.
http://www.altera.com/literature/an/an404.pdf- Mark as New
Sorry to keep you waiting LarsD. I am still investigating on unity gain. The input to the IFFT block initially starts with FSM that generates 64 symbols (N = 64), 4 bits each symbol. Because IFFT block requires 8 bits, real and imaginary data, I use another block to mapped it to fit the requirement. The mapping it such as shown below: 0000 ---> -96 - j96 0001 ---> -96 - j32 0010 ---> -96 + j96 0011 ---> -96 + j32 0100 ---> -32 - j96 0101 ---> -32 - j32 0110 ---> -32 + j96 0111 ---> -32 + j32 1000 ---> 96 - j96 1001 ---> 96 - j32 1010 ---> 96 + j96 1011 ---> 96 + j32 1100 ---> 32 - j96 1101 ---> 32 - j32 1110 ---> 32 + j96 1111 ---> 32 + j32 Negative numbers represented in second compliment. Then the output from IFFT is connected directly to FFT. After that, in order to do scaling, I created another block for that by refering to the source given by 'thepancake', did some modification and wrote the code in VHDL. So I test the blocks with single type of symbols first, meaning all the 64 symbols are 0000 or 0001 or 0010 and so on until 1111. I find that the final output that I get is the same with the input to the IFFT block. However, when I tried mixing several symbols together in the 64-length, then the results becomes different, it is not the same as the my input to the IFFT block. I attached my project files, in that project the 64-length input is 1111,1111,1111,1111,0000,1111,...,1111 (total 64 symbols). The output is completely different from what I expected. Suppose the output should be 32 + j32, 32 + j32, 32 + j32, 32 + j32, -96 - j96, 32 + j32, ... ,32 + j32. But the output turns out to be 32 + j32, 32 + j32, 32 + j32, 32 + j32, -144 - j144, 32 + j32,..., 48 + j48, 32 + j32, ..., 64 + j64,32 + j32,... ,32 + j32. Need to run the project to see total waveform. I used functional simulation mode. The device is Cyclone II. Quartus 8.1 web edition. I wonder what caused the output to be like that.:confused:- Mark as New
Just answered the same question... see the other thread....
Right after reset_n is asserted, sink_ready isn't asserted yet... if I recall correctly, it stays de-asserted for one cycle (can be more, I don't remember).... essentially, you are sending data to the core before the core is ready to accept more data.... hence you are getting the 11 error.... and this is also why sink_ready de-asserts as well...
hi bellman,I met the same problem as you said, if I mixed the real and imaginary data I find that the outputs change, if you finish this project, I'd like to see and thank you
- « Previous
- 1
- 2
- Next »
