FPGA Intellectual Property
6670 Discussions
FFT implemented within MAX 10 FPGA
torquay_mark
Does anyone have experience of FFTs within the MAX10 family? I note that these devices do not feature DSP blocks but do contain 18X18 multipliers. Are multipliers, LEs and RAM all that this IP requires for implementation?
I have created a qsys FFT block to my requirements in a project targeting the MAX 10 and generating the block gave no errors but I assume the resources are only checked at compile time?
Mark
CheePin_C_Intel
Hi Mark,
As I understand it, you have some inquiries related to the FFT IP support in Max 10 devices. For your information, as I refer to the FFT IP Core User Guide -> "DSP IP Core Device Family Support", the Max 10 is supported for FFT IP. Therefore, there should be no issue for you to instantiate the IP in the device.
Please let me know if there is any concern. Thank you.
Chee Pin
