FPGA Intellectual Property
FFT_tb
Hi !
I created 16 FFT code by using megawizard. I ran its stimulation by using the test bench code which megawizard created.
It is running only for 4 frames. I modified the frame number and its source files( sink_real.txt and sink_imag.txt) but I couldnt run it for more frames.
I want to run it for 16 frames. Did anyone try this ? Is it possible ?
thanks
If you're using fft_tb.v then you need to edit line 51:
parameter NUM_FRAMES_c = 4;
To what you want.
For fft_tb.vhd you need to edit line 56:
constant NUM_FRAMES_c : natural := 4;
Does that help?
I am using VHDL .I have editted the line 56 I didnt work.
I figured out the problem .
We have to edit also line 59.
signal fftpts_array : fftpts_list_t := (16, 16, 16, 16);
this array legnt must be the same with the frame number..
Thanks a lot
