FPGA Intellectual Property
6672 Discussions
FPGA AVMM DMA evaluation software
TinyPenguin
Where to download the Windows driver and application to evaluate the "AVMM DMA" design? Files like "Windows_for_AVMM_DMA_On_Chip_Mem.zip" mentioned in AN690 and "Gui package 090 80000000.zip" in the link below are missing.  Thank you!
https://www.intel.com/content/www/us/en/design-example/714456/intel-arria-10-fpga-an690-pcie-3-0-x8-avalon-memory-mapped-direct-memory-access-dma-design-example.html
https://community.intel.com/t5/FPGA-Wiki/Reference-Design-Gen3x8-AVMM-DMA-Stratix-10/ta-p/735907
Wincent_Altera
For Arria 10 AVMM DMA, can you please try this
https://community.intel.com/t5/FPGA-Wiki/Reference-Design-Gen3x8-AVMM-DMA-Arria-10/ta-p/735904?wapkw=Gui_package_090_80000000%20zip
I try it and I was able to download it
Wincent_Intel
TinyPenguin
Only Windows software revision 1.1 can be downloaded from this link which contains the executable file.   There is no driver file or any documentation inside the downloaded file.  Still need help.  Thank you!
Wincent_Altera
Hi Penguin,
You can use the revision 1.1 driver (the latest we provided) where you can run
You can get the window driver path via  C:\PCIe_EP_example_design\software\windows\interop\Altera_PCIe_X_Test\Altera_PCIe_X_Test\Windows_driver\64-bit
For the documentation, you may get it from either
https://www.intel.com/content/www/us/en/design-example/714462/intel-arria-10-fpga-an708-pcie-3-0-x8-avalon-memory-mapped-direct-memory-access-dma-with-external-memory-design-example.html
or
https://www.intel.com/content/www/us/en/design-example/714456/intel-arria-10-fpga-an690-pcie-3-0-x8-avalon-memory-mapped-direct-memory-access-dma-design-example.html (link you provided early)
Hope this clarified,
Wincent_Intel
TinyPenguin
The path on C drive you provided does not exist on my computer.  Which design package should I install to have that path and related drivers?   Thanks!
Wincent_Altera
Hi Penguin,
Do you compile the design ?
Once you compile the design it shall available in "software" folder.
Wincent_Intel
TinyPenguin
I test both design packages (an708 and an690) and compiled them successfully, but I still can not find the "software" folder in the project folders or anywhere on my harddisk containing the related driver files.  One screenshot attached.  Thanks!
Wincent_Altera
Hi Penguin,
Normally the driver would store under example
C:\intelFPGA_pro\22.1\ip\altera\altera_pcie\altera_pcie_a10_ed\software\windows\project\Altera_PCIe_project_zip.v
Can you please try to check again ?
Also can try out this as well https://community.intel.com/t5/FPGA-Wiki/Reference-Design-Gen3x8-AVMM-DMA-Arria-10/ta-p/735904?wapkw=Gui_package_090_80000000%20zip
Wincent_Intel
Wincent_Altera
I wish to follow up with you about this case.
Do you have able to get it ?
Wincent_Intel
TinyPenguin
I found the driver files in the zip file, and tested them to be working.  Thank you very much for the help and support!
Wincent_Altera
Hi Penguin,
Glad that you are able to find it, also thanks for sharing with me the result
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
Wincent_Intel
p/s: If any answer from the community or Intel Support is helpful, please feel free to give the best answer or rate 9/10 survey.
kam4
Hi Wincent,
Previously I used AN690 design and utilized driver for linux .
 this link now is broken : https://www.intel.com/content/dam/altera-www/global/en_US/uploads/f/f3/Linux_for_AVMM_DMA_On_Chip_Mem.tar.gz
Can you please help me with the package.
