FPGA Intellectual Property
6113 Discussions
Fitter can not place PERST pin for Multichannel DMA PCIE
ArleySalvador
Hi guys,
I am trying to compile the Example Design for Multichannel DMA PCIe IPCore. However the fitter plan stage failed and the following error has been reported.
The issue appeared when I initially choose the partnumber 1SG040HH3F35E3VG.
On the other hand I can successfully compiled the same project with 1SG065HH3F35E3VG partnumber, which is pin to pin compatible.
Error message:
Info(175028): The pin name(s): pcie_rstn_pin_perst
Error(175006): There is no routing connectivity between the pin and destination HSSI_CR2_PHIP2_CORE
Info(175027): Destination: HSSI_CR2_PHIP2_CORE dut|dut|hip|altera_pcie_s10_hip_ast_pipen1b_inst|wys
Error(175022): The pin could not be placed in any location to satisfy its connectivity requirements
Info(175021): The HSSI_CR2_PHIP2_CORE was placed in location HSSICR2PHIP2CORE_5TL0
Please find attached the two arquives project for 1SG040HH3F35E3VG and 1SG065HH3F35E3VG.
wchiah
Hi Arley,
We do not receive any response from you to the previous answer that I provided.
Also, I strongly believe that my previous answer had solve your problem (Please correct me if I am wrong)
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
wchiah
Same question been ask in
https://community.intel.com/t5/FPGA-Intellectual-Property/Fiiter-can-not-place-PERST-pin-for-Multichannel-DMA-PCIE/m-p/1414059#M26277
Do you need me to support you here or at the previous one ?
I shall close either one a duplicate.
Let me know if you have any other idea.
Wincent_Intel
wchiah
Please allow me to have sometime to look at the .qar file.
Get back to you soon as possible.
Wincent_Intel
wchiah
Hi Arley,
Can you try to
set_instance_assignment -name VIRTUAL_PIN ON -to *pipe_sim_only*
set_instance_assignment -name IO_STANDARD "3.0-V LVTTL" -to pcie_rstn_pin_perst
ensure pcie_rstn_pin_perst is whatever this port is called in your top level.
the information contained within the S10 PCIe Example Design User Guide,
can you ensure that you have the following two assignments in your test project:
Wincent_Intel
ArleySalvador
Hi Wincent,
I just confirmed that both constraints are present in my QSF.
Additionally, the pcie_rstn_pin_perst pin is connected to the top level interface.
I have attached the QAR file here.
Arley
wchiah
Thank for your response, I assume the same error still happen right ? the problem seen more clear to me.
In that case, There is a method on my mind that worth to try for us to narrow down more further
Let me know if this helpful. Looking forward to hear back from you.
Wincent_Intel
wchiah
I wish to follow up with you about this case.
May I know if the error still occurs again?
Wincent_Intel
wchiah
please allow me to correct it before closing or please let me know the cause so that I may improve your future support experience.
Wincent_Intel
ArleySalvador
Hi Wincent,
Sorry for my late response.
I have tried your suggestion
And I still didn't get a the perst pin placed by the tool.
Arley
wchiah
Hi Arley,
Is okay, I still remain this open for three days after my last message in case you reach back.
I see there is a three settings for the pin,  if follow the KDB provided.
Can you please just remove other settings that you make before but remain the "set_instance_assignment -name USE_AS_3V_GPIO ON -to pcie_rstn_pin_perst" ONLY as per mention in the KDB ?
To avoid any miss match, I would suggest you to generate a brand new design for that.
Hoping to hear back from you.
Wincent_Intel
ArleySalvador
Hi Wincent,
I have created a new project based on example design and set the USE_AS_3V_GPIO according to your suggestion and the problem continue.
Have you see the QAR file that I sent you?
Have you seen similar issues on that?
Arley
wchiah
Hi Arley,
Please allow me to have sometime to investigate on this issue.
Wincent_Intel
wchiah
Hi Arley,
Apologize for late reply, I use the .qar file provided by you pcie_ed_22_2_0_94_1sg040_Failed.qar
Initially it fail, I got the exact error as you, but after implementing the solution stated in the KDB.
I was able to run 100 % full compilation without any error
Could you please try it again ?
Wincent_Intel
wchiah
Attach with the success .qar file
wchiah
Hi Arley,
Are you able to run the full compilation with the solution I provided?
Do you still have any questions on this?
Else I would like to have your permission to close this ticket from my side.
Wincent_Intel
wchiah
Do you have any further questions on this matter ?
​​​​​​​Else I would like to have your permission to close this forum ticket
Wincent_Intel
wchiah
Hi Arley,
Wincent_Intel
ArleySalvador
Hi Wincent,
Sorry again for my late response. I have tested and it is solved.
Thank so much for your great support.
Arley
