FPGA Intellectual Property
6670 Discussions
Generic Serial Flash Interface Intel FPGA driver
acvin
Hi all
the official Intel documentation refers to a NIOS2 BSP driver here
https://www.intel.com/content/www/us/en/docs/programmable/683419/22-2-20-2-1/hal-driver.html
However I do not find any when generating the BSP editor components.
Since I am using Quartus 20.1, I checked how I can activate the altera_safelibs mode, with any luck. Do you have a tutorial on how to do that?
Thank you
Best regards
KennyTan_Altera
Thanks for using Intel community forum,
Kindly expect some delay in the reply due to holiday.
Kenny
hareesh
Hi @acvin ,
altera_safelibs  is available in Quartus  pro Edition only. on Quartus® Prime Standard Edition and Quartus® Prime Lite Edition HAL GSFI drivers and altera_safelibs option not available. planed this for Quartus® Prime Standard Edition 23.1.
if you are using Quartus  pro Edition then pls visit bellow given link.
link:
https://community.intel.com/t5/Nios-II-Embedded-Design-Suite/HAL-API-for-the-Generic-Serial-Flash-Interface-FPGA-IP-altera/m-p/1393340#M51247
thanks,
hareesh
Hi @acvin
Since I had provided you the solution and did not received any feedback from you, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, some one will be right with you.
thanks,
