FPGA Intellectual Property
6359 Discussions
Generic serial Flash interface sector erase problem
Gyud0
Hey,
I'm using the Reference design Generic Serial Flash Interface IP on Quartus Prime 18.1 to access Micron MT25QL512Mb flash memory.
Via NIOS processor, I able to erase the memory sector 0 (at address 0x00000000) data correctly in the 4-Byte address mode by the function:
void erase_sector_micron()
    IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x7,0x000004DC);
    IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x9,0x00000000);
    IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x8,0x1);
But when I try to erase another sector, like sector 1, I don't see the erasing actually happens:
    IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x9,0x00010000);
The sector 1 address is 0x10000 according to page 19 in the Datasheet:
https://media-www.micron.com/-/media/client/global/documents/products/data-sheet/nor-flash/serial-nor/mt25q/die-rev-b/mt25q_qlkt_l_512_abb_0.pdf?rev=0ef0faa5f7b645d7bc11c30bfd27505b
I would like to get some help here,
Gyud0
Can you help me please?
hareesh
hi Gyud0
I am working on it. please give me some time.
thanks.
hareesh
hi GAL YUD,
please check WRITE ENABLE command is executing or not before initiating ERASE command. in you shared code lines WRITE ENABLE command is not there.
thanks,
Gyud0
I'm executing the write enable command before I initiating the erase command. It's the same order that I do successfully in erase sector 0, the only change is the desired address to be deleted
hareesh
hi @Gyud0 ,
can you share your code pls
thanks,
hareesh
check lock protection enable or disabled. before erase sectors needs to disable lock protection. pls check that.
Gyud0
My code in C:
int main()
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x7,0x00000006); --Write enable
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x8,0x00000001); --Write enable
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0xA,1); --Write enable
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x7,0x000004DC); --Erase sector
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x9,0x00010000); --Erase sector
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x8,0x00000001); --Erase sector
hareesh
Hi @Gyud0 ,
It's not a GSFI (Generic Serial Flash Interface) IP driver issue. The GSFI drivers are working fine. Please check Micron MT25QL512Mb flash memory access code because before erasing the sector, you have to disable device lock protection, write command passing, and some other commands also have to execute. In the Micron MT25QL512Mb datasheet, all the details are available. I am giving some  reference example code links for the Micron MT25QL512Mb.
link:
https://github.com/STMicroelectronics/stm32-mt25ql512abb
thanks,
