FPGA Intellectual Property
6594 Discussions
HARD IP DDR3 with UniPHY + ArriaVGX: too long not local_ready
Hello!
I am long enough work with DDR/DDR2/DDR3 IPs using Altera Device's. But this see first time.
I use 2 chips together (32 bit width) Hard IP DDR3 600 MHz. And see that during long read write transactions local_ready signal may not ready up to 1.12 us (1400 tacts of 125MHz clock). I specially at first write RAM then read using bursts and do it repeatedly (in loop). And see these holes in ready very often... I have no any timing slacks after compilation. IP was created with megawizard.
What is it? Refresh? Why is so long?
Any suggestion?
Please Help! )
Problem has been solved. If change parameters to control refresh then local_ready nearly always ready (but refresh must be done every 4 us). In my case I don't do refresh at all because algorithm which works with RAM write and read from the start address to N address without delays (all needed rows are always charged).
Goodluck to every one!
