FPGA Intellectual Property
HDMI Long Lock Time
JLee25
I am facing the Rx long lock time issue on HDMI 2.0 resolution.
I am using Cyclone 10 GX + Quartus 19.2.
Do you know how to reduce it?
Thank you!
BRs,
Johnson
Deshi_Intel
Hi Johnson,
May I know are you using Intel HDMI IP or your own HDMI IP ?
Are you referring to Intel HDMI sink "locked" or "vid_lock" issue ? Some lock scenario example as below.
  • Have you ensure you are sending all valid HDMI data ?
  • If user is sending invalid control data, then the LOCKED port from the HDMI RX core will be deasserted.
  • If user is sending valid control data, but invalid Data Island, then they will see LOCKED port asserted but VID_LOCK deasserted.
  • locked [2:0] should have 3 bits. Do you see different result within these 3 bits ?
  • Does upgrading to latest Quartus version helps to resolve issue ?
Have you isolate the issue to find out under what operating condition that you observe slow lock time ?
  • Like does it has dependency on certain video resolution change ?
  • Does reducing video resolution helps to see if this issue is related to signal integrity concern ?
Finally, have you isolated whether the bottleneck resides in HDMI IP, or PLL or transceiver channel ?
  • Did you probe PLL lock, transceiver CDR lock or rx_ready signal and compare with HDMI lock status ?
dlim
JLee25
Hi Dlim,
Thanks for getting back.
I am using Intel HDMI IP and the the long lock issue was mentioned on,
https://www.intel.com/content/www/us/en/programmable/documentation/ezu1511767661589.html
I noticed this in my latest compilation resolution, same hardware and same source...
In my previous test, there's no long lock issue..
FYI!
BRs,
Johnson
Deshi_Intel
Hi Johnson,
Thanks for pointing out the long lock time limitation in C10 GX HDMI design example doc.
I want to clarify further with you first before I check with Intel Engineering team on long lock time issue fix update.
  • May I know are you using just HDMI IP or HDMI design example that encounter this long lock time issue ?
  • V19.2 : you countered long lock time issue
  • You also mentioned previous Quartus version doesn't face this issue. Can you let me know which previous Quartus version is working fine ?
dlim
JLee25
Hi Dlim,
For this issue, I am using HDMI IP on custom board and Quartus Pro V19.2.
I used to test HDMI reference design on C10 GX EVB, Q18.0.1..
I am asking because I noticed the Rx is always work with 1080p but not UHD...
And I want to clarify this issue is coming form the IP or Signal Integrity.
Thank you!
BRs,
Johnson
Deshi_Intel
Hi Johnson,
Ok, thanks for providing more info but let's not mix up the 2 issues here.
  1. Regarding UHD is not working issue
  • There are a lot of factor that may impact the functionality like Quartus design timing closure, board signal_integrity, transceiver link tuning and etc
    • You need to slowly isolate the issue first
  1. Regarding HDMI slow lock time issue
  • For this, I have clarified with Intel Engineering team. I get a better understanding now and sorry for the confusing design limitation write up in the HDMI design example doc
    • What the attached design example statement screen shot means is
      • using HDMI IP only, it won’t achieve fast lock time
      • As a workaround, user can follow HDMI design example to use the symbol_aligner.v design to improve the lock time.
dlim
