FPGA Intellectual Property
HIL block
When i am using HIL block only output port is generated not the input ports what should be the solution? plz reply
I don't know much about HIL, but you could try looking at the design examples, there's an example at 13-3 here: http://www.altera.com/literature/hb/dspb/hb_dspb_std_lib.pdf
