FPGA Intellectual Property
6424 Discussions
Hardware In The Loop
Hi there,
i have a model in HIL way. it is very simple,in this model data will be multiply by a constant number then the results will be stored in a shared memory. after i run the model and compile it in quartus and program it in fpga,i should write/read data via Matlab API functions.
i read some pdf files about this but i cant figure out how to deal with this problem.
can anyone help me with this,
thanks
babak
i solved it. the problem was in address mapping.
