FPGA Intellectual Property
6673 Discussions
How do I obtain OpenCore Plus IP licensing?
MPaz
I have had an engineering firm develop a NIOS FPGA design based on the MAX10. During the development, I wrote and tested NIOS code using Quartus Prime Lite. I am now taking on full control of the design and have purchased a standard license of Quartus Prime in order to generate an un-tethered, non time-limited program file.
When I tried to compile the design using the standard license, I am unable to generate a non time-limited program file since the design uses 16550 UART IP and says I need an OpenCore Plus license.
I have been unable to find any information on the how to get this license. The FPGA design was completed using version 17.1.0 Build 590.
Vicky1
Have you resolved the issue?
May I know any update or Should I consider that case to be closed?
Vicky
