FPGA Intellectual Property
6605 Discussions
How do you use the Avalong memory map to interface external memory
thedas
I am trying to access data from a DDR4 SDRAM connected to an Arria 10 and store it in a fifo buffer sequentially, and I read that you can use an emif hard memory controller to access the DDR4 memory through the avalong mm interface, but I do not know how I would go about doing it . I am quite new to using FPGAs so any help would be much appreciated.
NurAida_A_Intel
You can refer to this Avalon handbook which defines all the Avalon interfaces and how it operate in details --> https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
Hope this helps.
NAli1
