FPGA Intellectual Property
6669 Discussions
How to configure the XCVR serial loopback for DP TX/RX IP core
CJian2
After building the DP TX/RX IP core example design, how to configure the XCVR serial loopback​ to let the TX video loop to RX?
Would someone please give some suggestion. thanks in advance!
Vicky1
For serial loopback mode you need to use Native PHY IP Core, refer the Figure 32. Simulation Example Block Diagram for Arria V, Cyclone V, and Stratix V Devices from the following link,
https://www.intel.com/content/www/us/en/programmable/documentation/hco1410462777019.html
Check common interface: Control and Status ports under the Table 16-16: Native PHY Common Interfaces,
https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/ug/xcvr_user_guide.pdf
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
