I am tried to converter old pll in quartus 13.1 to quartus pro 21.x
OLD ALLPLT has scanclk/scandataout port from tool .
// synopsys translate_off
`timescale 1 ps / 1 ps
// synopsys translate_on
module pll_cnfgrbl (
areset,
configupdate,
inclk0,
scanclk,
scanclkena,
scandata,
c0,
c1,
c2,
locked,
scandataout,
scandone);
input arese
how to generate same PLL for s10 ?
I can't see scanclk/scankena/scnadata pin option in quartus pro 21.x
That IP is not compatible with S10. You have to create a new Intel PLL IP for it and copy over the settings. The options you mention may not be available for the newer PLL.
I know that I have to generate,
but how to do for ALLPLL.
in IOLL itel FPGA IP from quatur pro,
doesn't have
scanclk,
scanclkena,
scandata,
these pins.
That is why I don't re-generation.
In ALTPLL the scanclk, scandata etc are used for Dynamic Reconfiguration. In S10, PLL is different and the reconfiguration functionality can be achieved using IOPLL Reconfig Intel® FPGA IP Core: https://www.intel.com/content/www/us/en/docs/programmable/683195/20-3/core-references-14991.html
Also, the Dynamic phase shift ports are different: https://www.intel.com/content/www/us/en/docs/programmable/683195/20-3/dynamic-phase-shift-ports-in-t...
