I want to shift out 0x00 to TDO of the JTAG port internally. I used a Virtual JTAG IP core and performed a VDR Scan Shift. However, I could not reveive 0x00 at the TDO pin of the JTAG port.
The TDI, TMS, TCK and TDO of Virtual JTAG IP core are connected to the TDI, TMS, TCK and TDO of my design. In my design, TDO is connected to a register assigned by 0x00.
The setting parameters of the Virtual JTAG IP core after compiling are as follows:
- Instance Index = 0
- IR Width = 1
- Address = 0x10
- USER1 DR Length = 5
- VIR Capture Instruction = 0x0B
From outside of the device, I use an application to perform the following 3 command sequences (described in SVF format), but non of them give me 0x00 at the TDO.
- VDR Scan Shift with USER0 only
STATE RESET;
STATE IDLE;
SIR 10 TDI (00C); // USER0 command
Set TDI = HIGH, go to Shift_DR state and wait for TDO go down LOW.
- VDR Scan Shift with USER1 + USER0
STATE RESET;
STATE IDLE;
SIR 10 TDI (00E); // USER1 command
- VDR Scan Shift with USER1 + ADDRESS + USER0
STATE RESET;
STATE IDLE;
SIR 5 TDI (10); // Shift Address = 0x10
Please tell me the correct way to solve my problem.
Thank you very much!
S.T.Nguyen
