FPGA Intellectual Property
6614 Discussions
How to stop or cancel an “Read/Write AVMM DMA operation” after it begins ?
JET60200
Hi Intel experts,
Sometimes I saw  Arria10  " PCIe AVMM DMA operation” would consume much more time than it's expected.  Such as in normal case, the DMA operation will consume around “+35us” to complete its Task in the Descriptor Table, while in rare exceptional case, the DMA will consume around "+3000us" (or above) to complete a similar task in Desc table, which will break down our System Timing.
So I wonder whether there's any method to "Stop or Cancel" that current "exceptional" AVMM DMA operation, when we found it exceed EXPECTED duration. I check "AVMM User Guide", unfortnately found nothing about it.
If any one has some suggestion, that's great appreciated.  Thanks a lot
@SengKok_L_Intel , please help if convenient, Thanks
SengKok_L_Intel
One possible solution is to generate the Secondary Bus Reset from the host. It is available at the Bridge Control register Bit 6.
Regards -SK
JET60200
" One possible solution is to generate the Secondary Bus Reset from the host. It is available at the Bridge Control register Bit 6. "
-> Hello @SengKok_L_Intel ,
Sorry for the delay ,  but which document describes the mentioned " Bridge Control Register "  ?
Pls help to point it out,  so i could check it detailedly.  thanks
SengKok_L_Intel
You can search the "secondary bus reset" or "bridge control register" from the PCIe spec.
JET60200
Thanks @SengKok_L_Intel  for quick feedback,
I have no more questions on this ticket,  thanks for kindly support!
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
