Hello Support!
I use ASMI Parallel II Intel FPGA IP for access to MT25QU512.
This memory connected to Cyclone 10 GX by "AS config" sheme.
Before doing the following, i could write and read memory by avalon and jtag interfaces.
I performed the following steps on the AVL bus:
- read from RD_NON_VOLATILE_CONF_REG 0xafee
- write to WR_NON_VOLATILE_CONF_REG 0xafe2
After these actions, I no longer access to MT25QU512 by avalon and jtag .
I understand that I was writing incorrect values to memory.
How can I regain access to memory?
I have attached log from the programmer when writing the jic file
Thank you for contacting Intel community.
Did you follow ASMI Parallel II userguide?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-asmi2.pdf
Also, what do you mean by writing incorrect values?
Aiman
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
