FPGA Intellectual Property
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
6064 Discussions
I can't find MSI-X Upper adress.
I can't find upper address for MSI-X.
In PCI specification:
Message Control Next Pointer Capability ID – CP+00h Message Upper Address - CP+04h Table Offset - CP+08h
In PCI Express compiler guide:
Table 4–14 describes the MSI-X capability structure. 0x68 Message Control Next Cap Ptr Capability ID 0x6C MSI-X Table Offset BIR 0x70 Pending Bit Array (PBA) Offset BIR
Where the “Message Upper Address
”? I can't find them.
Can I use
0x058 Message Upper Address
From Table 4–13. MSI Capability Structure?
I'm use Arria GXII with Hard-IP.
You write “In PCI specification” but you don’t tell us which version. Most probably, it’s not the official one.
There is a free description of msi-x (http://www.pcisig.com/specifications/conventional/msi-x_ecn.pdf) with the proper (== final!) table structure details.
--- Quote Start ---
--- Quote End ---
The table is not two DWORD!!!
Right, the table is 4 (!!) DWORD: 1 for data, 2 for address and 1 for control.
