Does any one know where can i buy/get I2C, Phillips standard, Master and Slave, IP core? If possible, it will be better if it will be an open core. I want to implement it on my cyclone 3, FPGA (3.3V). Thanks a lot IdanLink Copied
--- Quote Start --- Hi, Does any one know where can i buy/get I2C, Phillips standard, Master and Slave, IP core? If possible, it will be better if it will be an open core. I want to implement it on my cyclone 3, FPGA (3.3V). Thanks a lot Idan --- Quote End --- Did you try the open core version? opencores.org/project,i2c It says it is compatible with the Phillips standard. Good luck. Bart
The mp3-player example (from the altera wiki) seems to use the opencores version, too.
